Accidents
Мнениеот Делян » 16 Ное 2007 20:53
това което е станало е те са тествали двигателите и самолета е прескочил спънките (не знам точно как се казват) за гумите и се е врязал много яко в преградата.
Мнениеот karadzhoff » 16 Ное 2007 22:59
karadzhoff
Регистриран на: 20 Юни 2005 22:01
Местоположение: Varna City
Мнениеот mitkobiker » 17 Ное 2007 14:37
Мнениеот karadzhoff » 17 Ное 2007 16:37
karadzhoff
Мнениеот karadzhoff » 17 Ное 2007 16:41
Снимки и едно видео за Airbus-а на Iberia:
karadzhoff
Мнениеот karadzhoff » 19 Ное 2007 15:12
На самолет MD-80 на American Airlines се е запалил левият двигател при излитане от летище Lambert-St. Louis International Airport за Chicago. Пожарът е бил угасен още на самата писта. На борда са се намирали 142 пътника. Няма пострадали. Все още се изясняват причините за пожара. Снимки:
karadzhoff
Мнениеот karadzhoff » 22 Ное 2007 20:00
Напоследък наистина лош късмет за Airbus:
Seven injured in Airbus A330 test flight depressurisation
Seven occupants of an Air Mauritius Airbus A330-200 aircraft were taken to hospital after a depressurisation incident yesterday (21 November).
The twin-jet, the first of two A330s ordered by the carrier last year was performing a customer-acceptance flight from Toulouse, the final step in the process before an aircraft is delivered. It had been due to be formally received by Air Mauritius in the next few days.
Ten people were on board the aircraft: three Airbus personnel, six from Air Mauritius and one representative of a supplier. Two pilots and an observer were in the cockpit at the time, while the others were moving around the cabin.
"While in the cruise there was a sudden decompression," says a spokeswoman for Airbus. "When it happened it was so sudden that there was no time for [those in the cabin] to grab oxygen masks. Some became dizzy and unconscious."
There is no firm information on the altitude of the A330 at the time. Standard procedures following decompression include performing a swift descent to an altitude of around 10,000ft where atmospheric oxygen density is sufficiently high.
Seven people were taken to hospital as a precaution although all but one have since been released. The Airbus spokeswoman describes the occurrence as a "minor incident" and says none of the occupants suffered serious injuries.
Относно Airbus-а на Iberia:
Iberia indicates Quito overrun A340 will be repaired
Iberia is leaning towards repairing the Airbus A340-600 badly damaged in a runway overrun at Quito in Ecuador two weeks ago, although the carrier has yet to reach a final decision.
The 18-month old jet, owned by the carrier, suffered damage to its left-hand engines and undercarriage during the 9 November accident.
A spokeswoman for Iberia says: “We think it will be repaired. But this is still to be decided.”
Investigators, engineers and assessors have been examining the jet in order to decide how to remove it from the accident site, at the northern end of Quito Airport’s runway 17/35.
И този на Etihad:
Toulouse A340 throttles not idled until 2s before wall collision
Flight-recorder information from the Airbus A340-600 involved in the Toulouse ground-test accident last week shows that the aircraft’s engines were not retarded to idle until two seconds before the jet struck its test-pen wall.
The aircraft, which had been performing an engine and brake test, was travelling at around 30kt (55km/h) at the time of impact.
French investigators have determined that the A340-600, which was undergoing pre-delivery checks, was being held at standstill with the parking brake on and all four Rolls-Royce Trent 500 powerplants running with a relatively high engine pressure ratio of 1.24-1.26.
Wheel chocks were not inserted under the aircraft at the time of the 15 November accident.
In an information telex to operators Airbus states that high-thrust engine ground runs are normally only performed on one powerplant at a time, with the corresponding engine on the opposite wing running at limited thrust to counterbalance. It adds that wheel chocks should be installed during such tests.
While the parking brake is set, the A340’s alternate brake system provides the brake pressure. This pressure was normal during the Toulouse A340’s engine run.
Investigation agency Bureau d’Enquetes et d’Analyses states that the aircraft, for as-yet undetermined reasons, began to move forward after the engines had been running for about 3min.
The Airbus communication says the crew applied brake-pedal input within 1-2s of the initial movement and switched off the parking brake; the regular braking system’s pressure rose to its normal level.
But Airbus adds that all four engine thrust levers were only retarded to their ‘idle’ setting about 2s before the aircraft collided with the wall. By that point the aircraft had been in motion for around 11s.
“There is no evidence of any aircraft system or engine malfunction,” says Airbus vice-president for flight safety Yannick Malinge. “Airbus reminds all operators to strictly adhere to [aircraft maintenance manual] procedures when performing engine ground runs.”
Investigations are still continuing into the accident which destroyed the aircraft and injured several of the nine personnel on board. The jet had been scheduled for delivery to Etihad Airways on 21 November.
SOURCE:Flightglobal.com
karadzhoff
Мнениеот Stoyan » 22 Ное 2007 22:13
Малко черен хумур. Наистина лош месец за Еърбъс. 340 от личната колекция с малки щети по него:
Турски самолет се разби, 56 души загинаха
Мнениеот SPEED_BIRD » 30 Ное 2007 09:53
ATC на живо от Бургас, България:
http://www.liveatc.net/feedindex.php?ty ... al-eu#lbbg
SPEED_BIRD
Мнениеот Toni » 30 Ное 2007 10:46
Мнениеот Nikilaki » 30 Ное 2007 16:41
Nikilaki
Регистриран на: 06 Яну 2007 03:41
Местоположение: Germany,Duisburg
Мнениеот Nikilaki » 30 Ное 2007 18:46
Nikilaki
Мнениеот karadzhoff » 30 Ное 2007 18:53
Ето малко повече инфо около случилото се (интересно, че точно този самолет днес е добавен като update на страницата на airfleets.net - Last updates
MD80 Atlas Jet TC-AKM):
Passenger aircraft crashes in Turkey
Turkish rescue crews have reportedly reached the wreckage of a Boeing MD-83 that crashed while on a domestic flight early this morning and reports say it appears all on board were killed.
Authorities told local media that all of the 49 passengers and seven crew on board are believed to have been killed in the early-morning crash of the aircraft, which was being operated for local carrier Atlasjet.
Based on preliminary information, the MD-83 crashed while on approach to the southern city of Isparta’s Suleyman Demirel Airport, which is surrounded by mountains.
The aircraft was on a domestic flight from Istanbul. It is thought it was being wet-leased by Atlasjet from World Focus Airlines and was registered as TC-AKM.
According to Flight’s ACAS database the aircraft was built in 1994. It had a manufacturer’s serial number of 53185.
MD-83 crew sighted airport before crash: Atlasjet
Turkish carrier Atlasjet says the Boeing MD-83 which crashed while preparing to land at Isparta early today suddenly lost contact with tower controllers during approach, adding that there is no immediate indication of a technical problem.
Flight KK4203 from Istanbul Ataturk crashed in a region of high terrain, on a 5,000ft peak west of the Kilic region and north of a village identified as Cukuroren. Kilic lies just to the northwest of Isparta Suleyman Demirel Airport.
The flight was a night-time service; it was scheduled to depart at 23:20 yesterday but the late arrival of the aircraft inbound from Pristina meant the take-off was delayed until 00:50.
Meteorological data from Isparta for the period around the time of the accident shows that weather conditions and visibility were good.
Forty-nine passengers and seven crew were on board the aircraft, leased by Atlasjet from World Focus Airlines. Three cabin crew were from Atlasjet while the other four crew members – both pilots, the cabin chief and a technician – were from World Focus.
Atlasjet chief executive Tuncay Doganer says: “Communication was established with the tower, over Isparta Airport, the airport was seen, and as from this moment communication with the aircraft [was] cut off.”
The airline was informed at 06:15 that the aircraft had crashed. Rescue teams have not found any survivors and recovery personnel have reportedly retrieved the aircraft’s flight recorders.
Doganer says the aircraft was conducting the final stage of its approach in preparation to land when contact was lost, adding there is no evidence that the aircraft had a technical problem.
He says: “The weather was moonlit and extremely appropriate for the flight. Our pilots have just returned from training and are extremely experience. It is not a point of issue that the pilots were sleepless or [lacking rest]. The [reason] as to why the aircraft could not reach the airport after seeing [it] will be determined at the end of detailed investigations.”
karadzhoff
Мнениеот Делян » 30 Ное 2007 19:11
Мнениеот Nikilaki » 30 Ное 2007 20:35
Nikilaki
Потребители разглеждащи този форум: Bing [Bot] и 7 госта
