NOTAMs
NOTAMs
Мнениеот harrier » 20 Мар 2004 14:37
Като гледам има доста NOTAM-и:
LBSF SOFIA
A0018/04 - ACFT SHOULD NOT TAXI ALONG TWY A/ALPHA/ IN THE AREA IN FRONT OF STANDS 22-25 WITHOUT FOLLOW ME-CAR. 15 JAN 12:25 UNTIL 15 APR 22:00 ESTIMATED
A0019/04 - TWY A/ALPHA/ IN SEGMENT FROM THR27 AND CROSS POINT WITH TWY B/BRAVO/ IS CLOSED FOR ACFTS WITH WING SPAN ABOVE 42M. 15 JAN 12:38 UNTIL 15 APR 22:00 ESTIMATED
A0054/04 - MAKE THE FOLLOWING HAND AMENDMENT IN AIP REPUBLIC OF BULGARIA ON PAGE AD2 LBSF-PDC/17 DEC 03: TWY F SHOULD BE READ AS AIRCRAFT STAND TAXILANE F. 28 JAN 09:34 UNTIL PERM
A0056/04 - TWY B /BRAVO/ CLOSED IN SEGMENT BTN RWY 09/27 AND JUNCTION OF TWY B WITH AIRCRAFT STAND TAXILANE F/FOXTROT/. 28 JAN 10:07 UNTIL 28 APR 21:00 ESTIMATED
A0058/04 - TWY B/BRAVO/ CLOSED IN SEGMENT BTN JUNCTION OF TWY B WITH AIRCRAFT STAND TAXILANE F/FOXTROT/ AND JUNCTION OF TWY B WITH TWY A/ALPHA/ FOR LOW-MOUNTED ENGINES TYPE OF ACFT /ALL TYPES OF AIRBUS AND ALL TYPES OF B737,B707,DC8/. 28 JAN 10:28 UNTIL 28 APR 21:00 ESTIMATED
A0060/04 - AIRCRAFT STAND TAXILANE F /FOXTROT/ CLOSED FOR LOW-MOUNTED ENGINE TYPES OF ACFT /ALL TYPES OF AIRBUS AND ALL TYPES OF B737,B707,DC8/. 28 JAN 10:38 UNTIL 28 APR 21:00 ESTIMATED
A0061/04 - METAL FENCE ERECTED PERPENDICULAR TO THE RWY AND AT A DISTANCE OF 160M FM THR RWY 27. DIMENSIONS OF THE OBSTACLE: 2M HEIGHT/420M LENGHT. DAY AND NIGHT SIGNAL LIGHTS NOT PROVIDED. 28 JAN 12:47 UNTIL 28 APR 21:00 ESTIMATED
A0082/04 - TRIGGER NOTAM-PERM AIRAC AIP AMD 01/04 WEF 18 MAR 04 SOFIA AD-CHANGE OF STAR. 18 MAR 00:00 UNTIL 01 APR 23:59
A0106/04 - TWY C CLOSED FM SUNSET TO SUNRISE. NIGHT LIGHTING NOT PROVIDED. 24 FEB 08:19 UNTIL 25 MAY 21:00 ESTIMATED
A0155/04 - ACFT STANDS 11 12 18 19 20 AND 21 CLOSED. 08 MAR 10:07 UNTIL 08 JUN 06:00 ESTIMATED
A0157/04 - TWY D/DELTA/ CLOSED IN SEGMENT BEGINNING BEHIND STAND NR.9 TO ITS JUNCTION WITH TWY A/ALFA/ 08 MAR 10:28 UNTIL 08 JUN 10:26 ESTIMATED
A0204/04 - OM RWY 09 OUT OF SERVICE. 23 MAR 11:00 UNTIL 23 MAR 13:00
A0205/04 - LO/SF RWY 09 OUT OF SERVICE. 23 MAR 08:00 UNTIL 23 MAR 11:00
A0206/04 - LM/S RWY 27 OUT OF SERVICE. 22 MAR 09:00 UNTIL 22 MAR 11:00
A0207/04 - DME/GOL OUT OF SERVICE. 24 MAR 09:00 UNTIL 24 MAR 13:00
A0208/04 - DME/KAL OUT OF SERVICE. 25 MAR 09:00 UNTIL 25 MAR 13:00
A0212/04 - ILLUMINATIONS WILL TAKE PLACE WI AREA RADIUS 1000M FROM POINT WITH COORD 424150N 0232105E. GND FL040 25 MAR 09:30 UNTIL 25 MAR 10:00
A0215/04 - ILS LLZ/ISF RWY27 OUT OF SERVICE. 18 MAR 08:12 UNTIL 24 MAR 11:00 ESTIMATED
A0217/04 - OM RWY 27 OUT OF SERVICE. 26 MAR 07:00 UNTIL 26 MAR 14:00
A0218/04 - MM RWY 27 OUT OF SERVICE. 25 MAR 07:00 UNTIL 25 MAR 14:00
A0219/04 - IM RWY 27 OUT OF SERVICE. 25 MAR 07:00 UNTIL 25 MAR 14:00
A0220/04 - ILS GP 27 OUT OF SERVICE. 26 MAR 07:00 UNTIL 26 MAR 14:00
A0221/04 - NDB/BOZ OUT OF SERVICE. 29 MAR 08:00 UNTIL 29 MAR 12:00
A0222/04 - RWY 09/27 CLOSED DUE TO WIP. 24 MAR 21:20 UNTIL 28 MAR 03:40 WED-THU 2120-0350 THU-FRI 2120-0500 FRI-SAT 2120-0350 SAT-SUN 2200-0340
A0223/04 - RWY 09/27 CLOSED DUE TO WIP. 28 MAR 20:20 UNTIL 12 APR 02:45 SUN-MON 2020-0245 MON-TUE 2020-0245 TUE-WED 2020-0245 WED-THU 2020-0255 THU-FRI 2020-0245 FRI-SAT 2020-0255 SAT-SUN 2225-0315
A0224/04 - RWY 09/27 CLOSED. 12 APR 20:20 UNTIL 13 APR 01:50
A0225/04 - RWY 09/27 CLOSED DUE TO WIP. 13 APR 20:20 UNTIL 12 MAY 02:45 ESTIMATED TUE-WED 2020-0245 WED-THU 2020-0245 THU-FRI 2020-0245 FRI-SAT 2020-0255 SAT-SUN 2225-0315 SUN-MON 2020-0245 MON-TUE 2020-0245
Мнениеот harrier » 28 Мар 2004 00:15
Избрани NOTAM's:
A0249/04 - RWY 09/27 CLOSED 11 APR 20:20 UNTIL 12 APR 01:50
Интересно какво ще правят с кацащите полети на Lufthansa и Austrian airlines около 2230?
A0252/04 - RWY 09/27 CLOSED DUE TO WIP 12 APR 20:20 UNTIL 12 MAY 02:45 ESTIMATED MON-TUE 2020-0245 TUE-WED 2020-0245 WED-THU 2020-0245 THU-FRI 2020-0245 FRI-SAT 2020-0255 SAT-SUN 2225-0315 SUN-MON 2020-0245
Какво е това WIP?
A0270/04 - ILLUMINATIONS WILL TAKE PLACE WI AREA RAD 1000M FM POINT WITH COORD 424150N 0232105E. GND FL040 02 APR 17:45 UNTIL 02 APR 18:15
Тука некои ще празнуват приемането ни в НАТО явно.
Мнениеот Toni » 28 Мар 2004 00:24
LH и АUA, ще трябва да кацнат по-рано и наче ще им се наложи да нощуват в Пловдив. Не знам какво е разписанието на 11-ти, но може това да засегне Малев и CSA.
И аз се чудя какво е WIP...
Абсолютно си прав за фойерверките на 2-ри.
Последна промяна Toni на 01 Апр 2004 00:49, променена общо 1 път
Мнениеот harrier » 28 Мар 2004 01:02
По-скоро ще кацнат след 1:50 отколкото преди 20:20. Иначе в Пловдив няма кой да ги пусне да нощуват :wink:
Мнениеот Гост » 01 Апр 2004 00:40
WIP - work in progress
Гост
Мнениеот Toni » 17 Юли 2004 17:36
LBSF SOFIA
A0376/04 - METAL FENCE ERECTED PERPENDICULAR TO THE RWY AND AT A DISTANCE OF 160M FM THR RWY 27. DIMENSIONS OF THE OBSTACLE: 2M HEIGHT/420M LENGHT. DAY AND NIGHT SIGNAL LIGHTS NOT PROVIDED. 27 APR 09:30 UNTIL 27 JUL 13:30 ESTIMATED
A0432/04 - ACFT STANDS 23 AND 24 COMPLETELY WITHDRAWN. 21 MAY 13:00 UNTIL PERM
A0484/04 - ACFT STANDS 11 12 18 19 20 21 AND 26 COMPLETELY WITHDRAWN. 07 JUN 10:05 UNTIL PERM
A0485/04 - ACFT STAND TAXILANE F /FOXTROT/ COMPLETELY WITHDRAWN. 07 JUN 13:45 UNTIL PERM
A0503/04 - JIB CRANE HEIGHT 56M OPERATING AT A DISTANCE 700M WEST OF THR27 AND AT 564M TO THE SOUTH OF RCL. JIB RANGE 52M. ICAO MARKED. 16 JUN 14:08 UNTIL 13 SEP 23:59 ESTIMATED
A0508/04 - ACFT STANDS 22 AND 25 COMPLETELY WITHDRAWN. 18 JUN 16:30 UNTIL PERM
A0577/04 - RWY 09/27 CLOSED 09 JUL 20:30 UNTIL 20 JUL 02:30 JUL 09-10 2030-0030 JUL 10-11 2230-0300 JUL 11-12 2030-0020 JUL 12-13 2030-0230 JUL 13-14 2240-0230 JUL 14-15 2140-0230 JUL 15-16 2130-0230 JUL 16-17 2030-0030 JUL 17-18 2230-0300 JUL 18-19 2030-0230 JUL 19-20 2030-0230
A0578/04 - RWY 09/27 CLOSED 21 JUL 21:40 UNTIL 29 JUL 02:30 JUL 21-22 2140-0230 JUL 22-23 2130-0230 JUL 23-24 2030-0030 JUL 24-25 2230-0300 JUL 25-26 2030-0230 JUL 26-27 2030-0230 JUL 27-28 2120-0230 JUL 28-29 2140-0230
A0579/04 - ILS RWY 27 DOWNGRADED TO CAT I 09 JUL 11:54 UNTIL 30 SEP 14:00 ESTIMATED
A0580/04 - WIP 200M EAST OF RWY 27 THR.TRENCH WILL BE 50M LONG, 460M WIDE AND 8M DEEP. 09 JUL 12:20 UNTIL 30 SEP 14:00 ESTIMATED
A0588/04 - TWY D /DELTA/ BTN ACFT STAND 6 AND ACFT STAND 10 CLOSED FOR ACFT WITH WING SPAN MORE THAN 68M. 16 JUL 11:00 UNTIL 15 OCT 11:00 ESTIMATED
A0589/04 - TWY J /JULIET/ BTN ACFT STAND 16 AND ACFT STAND 13 CLOSED FOR ACFT WITH WING SPAN MORE THAN 68M. 16 JUL 11:00 UNTIL 15 OCT 11:00 ESTIMATED
Мнениеот Делян » 17 Юли 2004 23:18
Мнениеот Toni » 17 Юли 2004 23:25
Мнениеот harrier » 19 Юли 2004 19:04
Mosta se podgotvq, a ako vidi 4ovek stroitelnite raboti ot vazduha 6te re6i 4e 6te stroqt 50 magazina Metro edin do drug, stava vapros za ogromna plo6t.
Мнениеот Делян » 19 Юли 2004 23:05
Браво, браво! Строят значи, пък и нали преди няколко дена правителството се сети да направи летището инфраструктурен приоритет номер 1.
Мнениеот slice » 26 Юли 2004 15:57
ne stroiat, a kopat... pone na men taka mi se stori ot samoleta... na vrashtane shte ogledam
Мнениеот harrier » 26 Юли 2004 18:44
Terminala go stroqt, a ina4e izravnqvat terena za novata polosa. Za tova suob6tih o6te prez Mai.
Мнениеот slice » 27 Юли 2004 18:41
az za pistata govorih
Мнениеот Toni » 29 Окт 2004 20:48
A0913/04 - TWY D CLOSED. 04 NOV 06:00 UNTIL 03 FEB 06:00 2005 ESTIMATED
A0917/04 - APRON TWY D/DELTA/ CLSD BTN ACFT STAND N6 AND ACFT STAND N9 FOR ACFT WITH WING-SPAN MORE THAN 68M 29 OCT 07:05 UNTIL 28 JAN 06:30 2005 ESTIMATED
A0920/04 - TAXIING OF ACFT ALONG APRON TWY G/GOLF/ WILL BE CARRIED OUT ONLY BY FOLLOW-ME CAR. 29 OCT 12:45 UNTIL 05 NOV 15:00
A0921/04 - TWY A/ALFA/ CLOSED. 29 OCT 12:52 UNTIL 28 JAN 15:00 2005 ESTIMATED
Започва хаосът, TWY A и D са затворени за 3-4 месеца. Явно ще копаят, променят геометрията и пагат нова настилка.
Мнениеот Делян » 29 Окт 2004 21:13
Назад към Спотърстване
Потребители разглеждащи този форум: 0 регистрирани и 8 госта
